Author Topic: How do you remove safe eyes when you have lost the password and pin  (Read 5626 times)
Offline Mitz
  • Administrator
  • Hero Member
    • Free Computer Tips
hi guys
Someone has sent this question to me in an email....It is a parental control program. Does anyone know anything about it and how to get rid of it.
Visit the main site, Tips4pc.
Everyone can learn something new everyday! :D
Offline DSTM
  • Sr. Member
Re: How do you remove safe eyes when you have lost the password and pin
« Reply #1 on: February 06, 2009, 10:18:54 AM »
Hi Mitz,I had a quick look on the Net,and from what I have read it's near impossible to remove,without a password or pin.
However, I read there are a few ways to By-Pass it. :)
Dak, may know of a fix.
Confidence is the feeling I get, moments before I stuff something up.LOL.
dak
  • Guest
« Reply #2 on: February 20, 2009, 11:07:29 PM »
I am glad I dont have this problem thats all I can say lol
Seems to me, after a fair bit of research, that there are 2 options.
1. Contact Safe Eyes themselves and see if they have a procedure for lost passwords.
2. Reinstall Windows !
Even registry fixes dont work on this one :(
Offline Mitz
  • Administrator
  • Hero Member
« Reply #3 on: February 21, 2009, 05:49:32 AM »
well I will not be having this program on my computer. That's just wrong to be in such a position. The person that sent this to me can hardly work a computer, let alone format one....
I thought I might post it here, because if anyone was going to find the answer it would be dak..BOO HOO HOO
Thanks you checking it out.. :)
Offline Drovers Dog
  • Jr. Member
« Reply #4 on: February 21, 2009, 09:03:02 PM »
Little Trick I some time use?
Download it again and try to install it?
Most times it will ask you if you want to Remove the old version, just remove the old Version and then abort the Install.
If it installs, you will get a new Password, use it to uninstall it.
It is the only way to get rid of AVG Free 8
Might be worth saving?
« Last Edit: February 21, 2009, 09:13:09 PM by Drovers Dog »
dak
  • Guest
« Reply #5 on: February 21, 2009, 11:00:45 PM »
An excellent thought and definitely worth a try :)
Offline Drovers Dog
  • Jr. Member
« Reply #6 on: February 22, 2009, 12:37:44 AM »
Just Happy to Help out, Mate!
If it works feel happy to use it. That is what Tips are all about.
Some times the older Generation finds little Tricks through just hard work?
Other Forums just ignore them because they can't Google it?
